Date:    2-29-2016
Number of Hours:    4.00
Brief Description:    GACOLATOR/FUEL FILTER SERVICING
REMOVE THE FILTER ELEMENT FROM THE FILTER HOUSING. BY CUTTING AND DISCARDING THE LOCKING WIRE.
HOLD THE FILTER RETAINING NUT WHILE LOOSENING THE JAM NUT.
INSPECT THE FILTER ELEMENT FOR CONTAMINATION, AFTER INSPECTION CLEAN THE FILTER WITH SOLVENTAND GENTLY BLOW DRY WITH LOW PRESSURE AIR.
REPLACE THE FILTER ELEMENT IN THE HOUSING.
SECURE THE FILTER BOWL WITH SAFETY WIRE.
