2-29-2016 |
4.00 |
ELECTRIC FUEL PUMP |
THE ELECTRIC FUEL PUMP MOUNTS FORWARD OF THE FIRWALL. 1 DRILL FOUR 3/16 HOLES IN THE FIRWALLAT THE LOCATION SOW IN CHAPTER 23 FIREWALL FORWARD. 2 MATCH DRILLTHE FUEL PUMP MOUNTING BRACKET TO THE FOUR HOLES. 3 SQUARE OFF THE SCREW HEADS AND BOND THEM TO THE FIRWALLUSING HYSOL OR FLOX. REF TO CHAPTER 2. 4 CUT FOUR SLOTS IN THE MOUNTING BRAKET, TWO ON EACH SIDE. 5 SLIDE THE HOSE CLAMPS THROUGH THE SLOTS SO THE FUEL PUMP MAY BE FIRMLY HELD TO THE MOUNTING BRACKET. 6 ENSURE THE FIREWALL BLANKET HAS BEEN INSTALLED ON THE FIREWALL PROIR TO INSTALLING THE MOUNTING BRAKCET. 7 ATTACH THR BRACKET TO THE FIRWALL USING WASHERS AND LOCKNUTS. |
