2-29-2016 |
2.00 |
CONNECTING THE GASCOLTOR/FUEL FILTER |
1 THREAD THE C5315 X 8 X 10 ELBOW FITTIGINTO THE OUT PORT OF THE GASCOLATOR AND TIGHTEN IT UNTIL THE ORING SEATS. 2 THREAD AN 8-12-C50X ELBOW FITTING INTO BOTH PORTSOF THE FUEL PUMP AND TIGHTE THEN UNTIL THE O-RING SEATS. 3 CONNECT HOSE 140-00063 BETWEEN THEGASCOLATOR AND THE FUEL PUMP. THE BELOW FITTING ON THE HOSE CONNECTS TO THE GASCOLATOR, THE STRAIGT FITTING CONNECTS TO THE INLET SIDE OF THE FUEL PUMP. 4 CONNECT HOSE 506A BETWEEN THE OUTLET PORT OF THE FUEL PUMP AND THE FUEL HEATER. THE ELBOW FITTING ON THE HOSE CONNECTS TO THE FUEL PUMP, THE STRAIGHT FITTING CONNECTS TO THE FUEL HEATER. |
