2-23-2016 |
4.00 |
FORWARD HYDRAULIC MANIFOLD |
THE FORWARD MANIFOLD IS A COMBITATION STYLE VAVLE THAT ROUTES HYDRAULIC FLUID FROM THE AFT MANIFOLD TO THE NOSE GEAR ACTUATOR, THE LEFT AND RIGHT MAIN GEAR ACTUATORS AND THE EMERGENCY BY-PASS VAVLE. 1 MAKE A 4 1/8 X 2 1/4 PLATFORM OUT OF PHENOLIC, 8 BID E GLASS, 08 G-10 OR 8 BID CARBON LAYUP TO MOUNT TO THE BOTTOM OF THE FORWARD MANIFOLD. 2 USING THE MANIFOLD AS A GUIDE , MATCH DRILL TWO HOLES THROUGH THE PLATFORM TO ACCEPT THE SCREWS. LENGHT AS REUIRED. 3 MOUNT THE SCREWS AND PLATFORM AS PER CHAPTER 2 4 MOUNT THE FORWARD MANIFOLD TO THE SHEET WITH WASHERS AND LOCKNUTS. 5 LOCATE THIS ASSEMBLY 1 1/4 IN FOONT OF THEFRONT LEFT SHEAR BOX PASSSTHROUGH. POSITION THE ASSEMBLE SUCH THAT THE HYD LINES ARE CENTRED THROUGH THE PASS THROUGH. 6 BOND THE ASSEMBLE TO THE FUSALGE WITH FLOX |
