Date:    2-22-2016
Number of Hours:    6.00
Brief Description:    FLUSHING THE ACTUATORS
THE ACTUATORSDO NOT NEED FLUSHING ON INITIAL STARTUP, BUT SHOULD BE FLUSHED ANNUALLY.
1 DISCONNEST THE ACTUATORS FROM THELANDING GEAR.
2 ATTACH HOSES TO THE UP AND DOWN PORTS, AND PLACE EACH HOSE INTO SEPERATE BUCKETS, FILLED WITH THE MATCHING AIRCRAFT HYD FLUID.
3 OPERATE THE ACTUATOR PISTON FLUSHING THE FLUID UPTO THE BUCKET ENSURING THE CLEAN FLUID IS MOVRD INTO THE ACTUATOR.
4 CONTINUE THE OPERATION UNTIL CLEAN FLUID IS SEEN COMING OUT OFF THE ACTUATOR.
NOTE
STRAIN THE FLUID FROM THE RETURN BUCKET AND CHECK FOR CONTAMINANTS.
5 RECONNECT THE HOSES TOTHE ACTUATORS.
