11-9-2015 |
2.00 |
weight on wheels switch |
1 ENSURE AIRCRAFT IS AT ENPTY WEIGHT AND SUPPORTED ON JACKS 2 REF TO FIG 8.2.L.1 WEIGHT ON WHEELS SWITCH 3REMOVE BOTTOM JAM NUT AND THE KEYED WASHER FROM THE SWITCH 4 THREAD THE SWITCH INTO THE MOUNTING FLANGE ON THE TRUNION UNTIL THE AWITCH CONTACTOR IS JUST TOUCHING THE TRAILING LINK. SNUG THE TOP JAM NUT DOWN AGAINST THE FLANGE. 5 REINSTALL THE KEYED WASUER ABD THE BOTTOM JAM NUT. TIGHTEN BOTH JAM NUTS SO THAT THE SWITCH IS HELD AT THE DESIRED POSITION. 6 CONNECT THE SWITCH TO THE ELECTRICAL HARNESS. 7 INSTALL SAFETY WIRE |
