Date:    5-27-2015
Number of Hours:    3.00
Brief Description:    INSTALLING AILERON TRIM SERVO
AN ELECTRIC SERVO IS MOUNTED IN THE LEFT AILERON TO DRIVE THE TRIM TAB FOR ROLL CONTROL.
NUT PLATE THE SERVO BRAKET. BRAKET (209-0171) NUT PLATE (K2000-060 RIVET ( AN426A3-40 .ATTACH THE FRI
LOOSELY INSTALL THE FRICTION LOCK BOLT ( 109-0015)
ASSEMBLE THE PUSH ROD AND FRICTION LOCK ROD. ROD (211-0019)
CUT THE DRIVE PUSH ROD TO LENGTH 3 5/8 INCH.
ATTACH THE ROD TO THE SERVO.
INSTALL THE SERVO INTO THE LEFT AILERON THROUGH THE TRIM SERVO ACCESS.
CUT SLOTS IN THE AILERON TRAILING ADGE AND IN THE TRIM TAB TO ALLOW CLEVIS ATTACHMENTS TO THE HORN. ELONGATE THE SLOTS ENOGH TO ALLOW MOVMENT OF THE PUSH RODS AND THE TRIM TAB DURING SERVO OPERATION.
ATTACH THE PUSH AND FRICTION LOCK RODS TO THE HORN.
ADJUST THE PUSHROD TO SET THE AILERON TRIM TRAVEL TO 20 DEG ( +2/ -2 DEG UP AND 20 DEG ( +2 / -2 ) DOWN FROM NEUTRAL.
