5-27-2015 |
2.00 |
BALANCING THE AILERONS |
SINCE THER IS NO COUNTERWEIGHT ARM TO MOUNT THE LEAD WEIGHT WITHIN, LEAD WEIGHTS ARE ATTACHED TO THE LEADING EDGE. THESE WEIGHTS ARE PROVIDED IN THE KIT. THIS COUNTER WEIGHT SYSTEM HAS NODRAG PENALTY AND IS SIMPLE TO BUILD. NOTE AFTER INITIAL BALANCING AND INSTALLATION.THE AILERON MUST BE CHECKED FOR CORRECT BALANCE, WHEN CONTROL SURFACE IS REPAIRED ALTERED PAINTED. USING A BALANCE FIXTURE COMPOSED OFF A LEVELED TABLE. TWO BALANCE POINTS.A CALIBRATED SCALE ACCURATE TO +/- 0.01 LBS. CALIBRATED LEVELING DEVISE. TAPE TRIM TAB IN NEUTRAL POSITION. iNSTALLL HANGE HARDWARE. MOVE AILERON THROUGH FULL RANGE OFF TRAVEL ENSUREING FREE MOVMENT. POSITION THE AILERON SUCH THAT THE CORD LINE IS LEVEL. THEM MEASURE THE WEIGHT AT THE INBOARD END OFF THE TRAILING EDGE. ADD OR REMOVE WEIGHT AS REQUIRED. |
