Date:    5-27-2015
Number of Hours:    4.00
Brief Description:    MATING THE AILERON TO THE WING
IDEALLY THE AILERON NEED TO BE FLUSH WITH THE WING TIP WHEN IT IS FITTED TO THE WING AND THE HINGES ARE CONNECTED.
CONNECT THE AILERON TO THE OUTBOAD FLAP HING ( 150-0043). SLIDE BOLT (AN3-10A) THROUGH THE AURORA SPHERICAL BEARING IN THE FLAP HINGE.ARM. REFTO SIG 7.2.A.3. THREAD THE BOLT THROUGH THE BRAKET AND TORQUE TO 20 TO 25 IN-LBS.
CONNECT THE OUTBOARD HINGE USING A BOLT (AN3-7A) AND NUT (AN365-1032A OR AN310-3 WITH MS24655-135 COTTER PIN.
TORQUW THE NUT 20 TO 25 IN-LBS.
CONNECT THE MIDDLE HINGE LAST
TORQUE SEAL THE NUTS.
