Date:    1-12-2016
Number of Hours:    8.00
Brief Description:    AFT PRESSURE BULKHEAD FITTING
TWO PENETRATIONS THROUGH THE BULKHEAD ARE REQUIRED FOR THE BOOT INSTALLATION. ONE PENETRATION IS FOR THR 5/8 SOURSE LINE THAT PULLS PS3 AIR FROM THE FIRWALL FITTING. THE REMAINING PENERTRATION IS FOR THE 3/8 FITTING THAT PULLS AIR FROM HARDWARE ( EJECTOR ASSEMBLY) TO THE WING BOOTS
1 LOCATE AND DRILL TWO HOLES IN THE AFT PRESSURE BULKHEAD ABOVE THE FLOOR LEVAL TO THE RIGHT SIDE OFF TE AIRCRAFT.
2 DECORE THE HOLES AND PACK WITH FLOX.
3 LAY CABON FIBER THREE BID LAYUP OVER THE HOLES.
4 INSTALL FITTINGS AN833-10D AND AN807-6D.
5 FIT EITHER 90 DEG ADAPTER ( FCM1534 ) OR STRAIGHT ADAPTER ( FCM1514) AS REQUIRED FOR BESTHOSE ROUTING.
