Date:    11-9-2015
Number of Hours:    2.00
Brief Description:    GEAR SHOCKS
1 ATTACH THE CYLINDER OF THE SHCK TO THE TRUNNION USING BOLTS, RUBBER WASHERS, A METAL WASHER, ANDA LOCKNUT AS SHOWN IN FIGURE 8.2.E.1 SHOCK TRUNNION ATTACHMENT.
2 ATTACH THE ROD END OF THE SHOCK TO THE TRAILING LINK USING A BOLT, TWO BUNA WASHERS, A METAL WASHER, AND A LOCKNUTAS SHOWN IN FIG 8.2.E.2 SHOCK TO TRAILING LINK ATTACHMENT.
3 TRORQUE THE NUTS PER FIGURE 8.2.H.5 MAIN GEAR TORQUE VALUES. APPLY TORQUE SEAL.
4. CHARGE THE SHOCK STRUT WITH NITROGEN TO 250 PSI.
NOTE DO NOT EXCEED 260 PSI
