Date:    2-12-2015
Number of Hours:    3.00
Brief Description:    Prep and prime rod ends
Cleaning and prepping rod ends so they can be primed.
small pushrod rod ends will not come out after being drilled for rivets. Will use spray primer close to holes to coat as much of the interior as possible.
Large rod ends have been removed and cleaned. Need to clean with acetone and dip? in liquid self etching primer. Also touch up inside pushrods.
Small pushrods turned out really ugly... rivets fell over drilled out 3 of 4. tried trimming rivets still ugly.
Re ordering parts... Need to find welder.
