2-11-2015 |
3.00 |
Drill pushrod tubes / rod ends |
Insert. rod end into pushrod tube and used drill press to drill six equidistant holes. clecoed in place. First drill with drill press seems to pull rod end into tube slightly. All holes drilled. One bit broke. small tubes drilled straight through |
