Date:    9-29-2014
Number of Hours:    4.00
Brief Description:    Fit and drill W925 B & C to flap brackets
clamped and drilled B & C angle to flap bracket.
Used new 90 degree angle drill - NICE!
Verified top bracket (flush to bottom skin 925B) was flush between ribs.
Drilled out rib holes.
Drilled out spar holes
Fitted skins and drilled out skin holes
CS 925B skin holes
Cleaned, deburred, and primed brackets
Primed last step at night to give primer several hours to cure (harden??)
