Date:    9-24-2014
Number of Hours:    1.50
Brief Description:    Assemble W-914 and rivet to spar
Assembled and riveted:
Rivet flush rivets to hold bearing in place
Fabricated a small reinforcement plate to provide backing for the W-914 to rib (on side) - I had drilled a couple of holes for the attach bracket to hold the wing to the uprights too close to where the bracket to rib holes were. One actually overlapped. Clamped in place and drilled out with bracket / rib step.
Riveted W-914 to rear spar and side rib.
