7-24-2014 |
10.00 |
Prep and prime and dimple inner skins |
Scored and removed plastic on top inner skin. (previously primed). Dimpled top inner skin except marked holes (used later for wing attach). Joined long and short bench to be able to work in longer skins. Deburred back of top outer skin. Tried leaving on plastic and keeping reamer running then hop from one hole to next. Worked well and much faster once rhythm /ace was established. MUCH better than stopping and starting. Scored and removed plastic around holes. Removed back plastic, scuffed and primed. Prep and drill holes for access plates. (Removed plastic, fit drilled, scuffed and primed) |
