5-25-2014 |
2.00 |
CS holes and rivet nut plates for fuel sender |
Need to CS and rivet nut plates to T-708. Fuel sender attachment! Scotch brite and cleaned outside (inboard side) - scotch brite and cleaned T-905 also. Primed both. Riveting nut plates to T-708 Used Qtip with acetone to clean up overspray on inside of holes from outboard side (inside tank side) - tank sealant should cover these but just in case, to prevent possible fuel contamination. |
