5-18-2014 |
1.00 |
assemble and fit fuel sender to t-708 access plate |
Cut and bent fuel sender wire per instructions and mounted to sender. Mounted sender to access plate. Test fit plate to rib / tank assembly and adjusted float position for full and empty locations. meets spec for no more than 1/8 inch space from top / bottom (full / empty. |
