Date:    5-12-2014
Number of Hours:    2.00
Brief Description:    Cut out and shape T-410 reinforcement plates
Cut T-410 reinforcement plates from ring, marked, cut, and shaped to fit rib / skin.
Marked all four and now everything is ready for the right wing too.
Took time to measure, and mark tank attach bracket. Copied section of plans (noted as full scale templates) cut out shapes and traced shape on angle. Discovered that I needed to mark the inside to be able to cut using band saw.
