Date:    5-8-2014
Number of Hours:    1.00
Brief Description:    Set flush rivets for spar nut plates
Need to rivet gun / bucking bar set rivets on spar nut plates.
Removed rear skin to get betting access.
Used new tungsten bucking bar - small but dense - worked well
Had to change out mushroom head to get close to spar doubler, used narrow flat extension.
All six rivets drove well, one is a 'little' high' will check tomorrow and see what I think. Its 9:45pm now.
Note - drilled out offending rivet and reset. Rivet tried to rise up again. Did light set with bucking bar, then drove head flush. Finished up driving rivet.
