5-1-2014 |
1.00 |
Drill inboard attach bracket holes and measure win |
Drilled three holes in inboard bracket. Drilled screw holes (#8 screw #19 drill bit) in splice strip. Finally put on rear skins and attached a plumb line on each end of wing. Measured for any twist in wing by measuring distance from rear spar end of skin to string. Was within 1/32". Plans allow for 3/32. Good Alignment! |
