3-7-2014 |
1.50 |
Laid out and found parts for flap and aileron bra |
Upcoming steps require constructing brackets for ailerons and flaps. Need to figure out orientation and placement on spars to double check where holes need to go and when. Some aluminum 3/4 x 3/4 angle need to be fabricated into brackets that attach to larger brackets. Worked out sequence and where and when holes need to be drilled. Verified I had correct parts and material. I will work on these between riveting sessions - these sessions require two people to safely and efficiently set. Creating cheat sheet of order and placement - make sure I don't mix up parts, drill holes too soon, or rivet wrong holes. . |
