2-20-2014 |
2.00 |
Setting up wing skeleton |
Attaching wing ribs to left front and rear spar. Setting up to drill out holes to size, then need to prep ribs and prime. All ribs attached to left spars. Discovered one rib with wire routing hole not drilled out. Fixed. Begin drilling tomorrow (using #30 reamer) - tried one hole in each rib attaching to rear spar. |
