1-26-2014 |
1.00 |
Set up to test fit right tank ribs |
Pulled out right tank skin. Re- flute ribs for test fit. Learned on left tank ribs that the last fluting position needs a GOOD squeeze. Lining up last three holes is hard. Last two are on their own web cut outs so they float a bit better. #3 is harder. Re- fluted each rib. Test fit. Some will need adjustment. |
