8-31-2013 |
3.00 |
Rivet #6 and #8 nut plates to left bottom spar |
Drilled out rivet from other day two times. Finally figured out process / method to reliably squeeze flush rivets. Used rivet tape to hold rivet then partial squeeze and check flush / fit, then finish squeeze slowly with firm pressure against flush head. Completed left spar nut plates and set up to do right spar. |
