Date:    2-14-2013
Number of Hours:    2.00
Brief Description:    Finish up tool box project
Riveted hinge halves to lid and box.
Riveted latch to front and tab to front lid.
Bent hinge wire, using drilled hole in back rivet plate as support and bending assist (with small help from rivet gun to complete bend - wire bent over close to back rivet plate and the rivet gun forced complete bend).
Drilled holes for handle straps - measure close and eyeball. Drill wandered off initial start point and so had to adjust second handle strap to match.
Overall turned out well.
