Date:    12-26-2014
Number of Hours:    12.00
Brief Description:    Prime and begin assembly of Left Flap - need to re
Primed all ribs, skins, etc. Dimpled ribs and skins. CS and dimpled for 906 B (l) bracket.
Began assembly riveting.
During process of riveting nose ribs / main ribs / nose skins the entire assembly developed a twist. About 1/2 inch. Looked at several angles and weighting skins / spar / ribs. but twist was REALLY there.
Decided to reorder parts (~$300) and rebuild left flap.
Basically month of Dec was a learning month - no forward progress, but lessons learned.
1. READ all instructions TWICE, identify every part and which ones to drill / rivet.
2. Check last work done to verify no missed rivets (forgot 3 rivets on FL-906 bracket until one skin was on, forgot / didn't notice that top skin should have had skin riveted to ribs BEFORE riveting bottom skin to spar)
3. Consider writing down next steps / starting point.
4. Keep up Builders log!!
