11-7-2014 |
3.50 |
Drill and cleco bottom skin to table |
Weighted bottom skin (FL-902) to table top. Clecoed spar wit spar holes hanging over edge. Drilling out every second hole (starting with second one back) for each rib (some go into 2x4 table frame - should not be a problem only need to be deep enough to nestle cleco on bottom of skin. Removed everything and discovered that I needed 5/8 ths drill. Back and forth to Orchard. Drilled first two holes and discovered that the table 2x4 frame was in the exactly wrong place. Marked and cut off 8' x " overhang with skill saw. Put everything back together, drilled holes again, took everything apart, and drilled out holes with 5/8ths bit. |
