Date:    4-29-2013
Number of Hours:    1.00
Brief Description:    Sand and epoxy trim tab foam wedges / ribs
Did a final fit on foam ribs and had to sand them down a bit.
Mixed epoxy and installed ribs. Clecoed and clamped.
Epoxy is setting up. Just read / realized that I should have match drilled the hinge.
Now I need to figure out how to clamp / mark / drill hinge.
Hope I don't need to order a whole new trim tab ....
