9-30-2012 |
5.00 |
Fitting elevator control horn to spar and rib |
Control horn holes to rib holes do not line up. Trying to figure out why. Filed the control horn inside surface and took everything apart re-adjusted things and finally got control hone to line up. Installed the control horn on rib/spar first then attached to skin. Still tight but it did finally work. Attached spar / rib / control horn to elevator skin. Re-assembled counterbalance arms. Clecoed counterbalance arm to skin / spar assembly. All holes drilled out top and bottom elevator skin to spar. Drilled all bottom holes to #30 so I can use pop rivets as allowed in plans. Drilled out all skin to rib holes #40. Will drill out control horn and counterbalance #30 holes after disassembly. |
