Date:    2-24-2012
Number of Hours:    4.00
Brief Description:    Cleco Rear Spar together and attach Outboard Hinge
Clecoed the two HS-903 rear spars with the HS-906 rear spar doubler. Drilled out with #030 drill bit.
Attached 8 HS-912 outboard hinge brackets and enlarged holes with #30 drill bit. Had to cleco from back with small clecos because hinge brackets were powder coated and made it too difficult to use large (#30) clecos.
Numbered hinge brackets from left to right 1 - 8
Marked rear spar left and right.
