6-1-2005 |
0.10 |
Air Conditioner and compressor |
Remember I told you the garage get hotter then hell in the summer. Well, I made a door where the side door of the garage is located and put a 16000 BTU/120volt AC in it. At least when the outside temperature in 110+, the garage is a cool 85 degrees. Pictures 2 and 3 are the compressor. I build a ply wood box with carpet inside and put the compresor inside. Since the unit is a non-oil unit it can get noisey. With the compressor in the box, the compressor sounds are greatly reduced |
