4-24-2006 |
5.00 |
Left Wing Main Spar |
Started the left wing construction. and I need to tell everyone that you need to read the plans carefully. While we were constructing the tail section the plans were very explicet. i.e. use drill bit 30, dimple with #6 etc. The wing plans are different. The plans from now on expect you to already know what drill bit to use, what countersink to use etc. Once I understood that, then the wing plans became easier to use. I ended up buying the wing videos so that makes the construction even easier. |
