1-23-2018 |
8.00 |
Joined the tail cone and center section together |
I saved bending the longerons until they were ready to install due to space considerations. The first one was a learning curve. (No pun intended). The second went a lot easier. The biggest advice is check the opposite plane to the bend to see if it's curving off of a flat plane. There is no way to get the correct curved path if you don't also chech for a flat plane along the way. |
