5-8-2015 |
1.00 |
New Engine Cowling Finish Work - Part 1 |
The new cowling for the RV-8 is turning out amazing. Here are some pictures from Friday. Most of the surface pinholes are filled now (gray filler) and most of the gaps are set between the top/bottom and back/fuselage. Oil door fit and finish is amazing. The cowling is going to look pretty sweet. Gelcoat next, then sanding, then primer... So close! |
