I built a new Rudder as a part of the RV-8 Rebuild and discovered after I mounted the control surface back to the Vertical Fin that the new fiberglass tip on the Rudder was *higher* than the old one! The only way to deal with this was to make a new fiberglass tip for the Vertical Fin. But this is more work than it should be because I have a VOR/GS antenna mounted on the top of the Vertical Fin and a careful cutout has to made in the sides of the tip to accommodate it. It also means that I had to redo the rear baffle in the tip since by default the back is open and looks kind of Okie. I am please to report that, while I was happy with the previous tip, the new one came out even better. The fit around the antenna puck is perfect and nearly looks like it came pre-cut that way! The rear baffle also came out nice and all the sanding and primer worked wonders on the final appearance. Another one of those jobs that I shouldn't of had to redo for the rebuild, but in the interest of building an even higher quality Ruby 2.0, proved to be time well spent!
