Date:    7-26-2011
Number of Hours:    1.00
Brief Description:    Ground Power Plug Mounted - Part 01
Installation of the Ground Power Plug was pretty straightforward. I used a chassis punch this time instead of a hole saw and I have to say the results are much nicer! The angle stiffener brackets from the old fuselage unriveted nicely and fit perfectly on the new installation. This is one of the few places where some of the original wiring will be reusable.
Everything seems to be going faster this time around. A lot has to do with the fact that I don't have to agonize over the How and Where aspects of the installation. I just look at the old fuselage and do it the same on the new one. Saves a lot of time and consternation, that's for sure. Also, a lot of the brackets and bits are already build and/or fabricated, so that saves time too.
