Date:    1-17-2010
Number of Hours:    1.00
Brief Description:    Fuel Pump Covers Installed
Since I was trial fitting the front carpet piece, I really needed to fit the two covers that go over the fuel pump and flow transducers. I want to actually run the engine the first few hours with these off to keep an eye on the fittings and check back regularly for leaks. But, it was good to make sure they fit and I could get access to all of the screws.
The covers are a little hard to see in the pictures, but they are right behind the stainless steel brake lines in the middle of the photo.
