11-8-2009 |
9.00 |
Oxygen System - Switching Controller - Part 5 |
In the last few pictures, I'm showing the VP-200 Annunciator indicating that Oxygen System is ON. The EIS-4000 is showing the current oxygen tank pressure at 133 PSI, and finally the HX engine display (far left side of the gauges, is showing an oxygen tank pressure of 129 PSI (I'd let a little bit of air out between the two shots; otherwise they would read the same.) So, all-in-all the Oxygen Switching system was quite a diversion, but came out very nice and is completely integrated with the aircraft systems. If I can convince GRT to add the altitude sensor discrete output and prompting to the HX firmware, the system will be outstanding! :-) |
