11-1-2009 |
1.00 |
Oxygen System - EDS O2D2 Power Cable Strain Relief |
The oxygen system's Pulse Distribution module, the EDS O2D2, will accept either three AA batteries or an external power input that can be connected to the aircraft's electrical system (through a 4.7v regulator!). The problem I found was that the little power connector that plugs into the bottom of the O2D2 unit is kind of on the loose side. I added two more of the melt-in nut inserts and then supported the cable with a small cable strain relief. Works great! |
