Date:    8-21-2009
Number of Hours:    1.00
Brief Description:    Oil Pressure & Temperature Probes - Part 1
The oil pressure transducer for the RV-8 is a standard VDO, variable resistance unit and is mounted to the firewall. The oil temperature transducer is a special aircraft unit that screws directly into the back of the engine's accessory case. The wiring was already stubbed out to the firewall, so all I needed to do add connectors, labeling, and some spiral wrap to neat'n up the installation.
