9-13-2009 |
2.00 |
Riveting & Glassing Hinges To Bot Cowling - Part 1 |
Riveting the hinges to the lower cowling was about the same as adding them to the top cowling. There were just more of them. Since I could only do one hinge at a time to assure that the resin setup correctly and without too much running, it took about 5 sessions to get it completed. Once it was done, I attached the lower cowl to the fuselage to double check my fits. I was pleased that even after the riveting, everything still fit nearly perfect. Yahoo! |
