Date:    2-21-2009
Number of Hours:    2.00
Brief Description:    Rear Stick Installation & Wiring - Part 2
You can see from the two sets of travel sequences that the cable layout came out perfect. The cable basically rolls and unrolls with the left/right movement of the stick.
With full down stick, the grip clears the back of the pilot's seat by about 1/4". Full left/right and back stick is also easily attainable without too much fidgeting around.
The front stick will be a little trickier because the bottom of the instrument panel is a little sketchy right now since I'm using the Plexiglass panel still and the bottom bend isn't there. But, I have to install the front grip to finish up the wiring.
