1-30-2009 |
4.00 |
Backbone Wiring Schematic - Version 1.21 |
Seeing as how the high-current, backbone wiring is mostly done now, it seemed that I had better update the diagram to reflect the numerous changes that were implemented during the installation. The changes reflected include the new Starter Light Logic Reverser (upper left), the new Grounding Tree (upper right), the revised wiring on the Starter Contactor (lower left), the new 12v/20amp Power Port (center left), the new Emergency Bypass Power Buss (center right), and the revised wiring on the Starter and GPU contactor studs. The diagram is getting pretty full these days, so its a good thing the installation is done! :-) You can download the high-resolution PDF of the diagram from this link: or You can download the high-resolution JPG of the diagram from this link: |
