Date:    10-10-2008
Number of Hours:    1.50
Brief Description:    Low Pressure Brake Fluid Lines - Part 1
I decided to run a 1/4" hard line from the Brake Fluid Reservoir around onto the #2 bulkhead and, insert a Tee fitting, then run Stainless Steel flex lines down to the Master Cylinders on the low pressure side. Over all, the system came out very nice and looks pretty sharp.
