Date:    10-8-2008
Number of Hours:    2.50
Brief Description:    Bent and Installed Right Brake Lines - Part 1
There are two 1/4" solid aluminum tube brake lines that snake their way up the gear towers around the fuel vent lines, and then out one of the lightening holes. They wrap around through a little mount and then connect to the bulkhead connectors over the front rudder pedals. There's no real "plan" on the plans for all the bends necessary for these things. You just kind of start at one end and bend a little here and bend a little there until you get to the other end. Oh my, if it were really as easy and just writing those words... At least the second one for the other side is a "mirror" image of the first which makes it a little quicker (notice that I didn't say "easier").
