Date:    6-22-2013
Number of Hours:    2.00
Brief Description:    Finishing fitting prop
Finishing the fitting of the prop. I set the pitch using the markings on the centres white hub as per the instructions - thought I have been warned to use a proper protractor to check that both blades are pitched exactly the same. I'll do this after firing up the engine and checking what revs I can get from the current pitch setting.
