7-12-2009 |
4.00 |
Elevator bell crank |
Back to work on the plane at last - have been working in Cambodia over the last few weeks so the building program has been on hold. Misused the alloy angle intended for the support brackets - but Peter T had some spare angle so was able to source some from him (thanks Peter!). Made up the support brackets and fitted and filed the bushes flush - then assembled the bell crank assembly. Then made the fitting template (jig) as per the manual. Drilled the mounting holes in the seat back (using the template) and trial mounted the assembly. All fitted well. Removed the assembly and stored for final fit later. Removed the rudder cables and rudder (all had fitted OK). Removed the rudder assemblies. |
