5-14-2009 |
2.00 |
More work on the pedal bar assembly. |
Some unexpected prep work with the pedal assemblies. The powder-coating filled the threads of the contained nuts in either end of the connecting tube - had to clean the threads out with the tap. Then found that the spacers wouldn't fit inside the assembly tops - powder coating again. Sanded out the inside of the tubes but still needed to sand down the spacers to fit. Made the stops from the left over 1"" tube - as per the manual." |
