2-6-2009 |
5.00 |
Firewall & rudder work |
Finished smoothing the rough cut firewall - draw filing and sanding. Long, slow process but it provided a break from thinking! Started finishing the rudder. The joint between the halves needed filing and then filling. Good side job to work on between the critical path work. |
